1 - 9 of 9 Posts
Hi Promaster Squad.
I just recently installed the Li-bim 225 isolator for my coach battery (100Ah LifePO4), and am not getting any charge unless I force connect the batteries via the momentary switch.The coach voltage is at 12.5V and the van (chassis) battery is at 13.9V... thus, I’m not sure why the isolator is not initiating charging. Has anyone else run into this problem? Solution?
Hi Markwdaisy, im not exactly sure about this but most newer vehicles after like 2008 i think have smart alternators rather than fixed voltage alternaters..these alternators paired with standard isolators wont work effectively.(only charging to 80%ish charge for second battery...
The solution is to use a DC to DC smart charger...it will use the vehicles alternater to fully charge your second battery...its functions as an isolater as well so no worries about draining your starter battery accidently.
Redarc makes a nice one BCDC1225D DC to DC charger that should work for you..its a little pricy but its an isolater,charger and solar manager as well if you plan to eventually use solar to keep your battery topped off. its changes input from alternator to solar based on if the vehicle is running...no need to use relays.
they make a few sizes but if you only have one 100ah battery you would want to get this model size...it goes up to 200ah incase you plant to add another battery in the future....im sure there are other companies that make these and maybe cheaper but like I said im not a pro.
I can’t see any reason for a typical conversion with solar needing a B to B charger (personally). I hardly ever charge from my battery and the few times I would, it’s hardly a big deal. Most here will disagree, of course, because like LiPo‘s B to B’s are the latest big fad and thus a must have item. 🙀
The reason would be to enable the OP to get a full charge on his second battery without bypassing his isolater....for some reason apparently hes having problems
Hi Promaster Squad.
Did the OP ever get this figured out???
Discussion Starter · #8 ·
yes I did... and I'm embarrassed to say, it was simply a poor connection to the ignition-engaged 12v line I tapped into. After looking at the wire-tap, I realized I hadn't gotten the entire sheath covering removed to make a solid connection. It since works great. However, I will be switching to a B2B charger as the 20min charge and 30min off relay makes charging slow for our battery bank when we're in a pinch and need to turn the car on. Wish I would've invested in the first place.
thanks for the reply. I would probably go with B2B, but I've already purchased the BIM so I'll see how it works for me.
1 - 9 of 9 Posts
