1 - 2 of 2 Posts
I've got the Legend plastic liner. I need to remove the headliner to install an rv airconditioner. Am I going to have to drill out the black plastic fasteners? And what can I use to replace the headliner? I tried removing one fastener so far with pliers and the stump is still in the rib. Thanks for any advice!
I'm not sure about the particulars of the headliner or those clips, but with most if they break off you can just push them though and install another. If they are just the push type clips there is a small tool that looks like a bent screwdriver with a split end for taking them out. That may help you remove them without damaging the clip or the headliner.
1 - 2 of 2 Posts
