1 - 4 of 4 Posts
Does anyone know if there’s a fuse for the driver side speakers? I’m not getting any sound out the door speaker or the tweeter on the driver side? I’ve checked the balance settings on the radio and it’s centered. So it’s not that.
Any help is greatly appreciated, thanks!
I'd start by pulling the radio because it's easiest. After you pull it, reseat the connector then test and shake the connector a little while testing. If that has no affect, pull the door panel and do the same. Speaker could be blown, but hard to test the run without another factory speaker with the factory plug.
Doing this worked! It was actually just a loose connection, thanks!
1 - 4 of 4 Posts
