1 - 1 of 1 Posts
PMC '15 . The Bulbs I've purchased from Amazon and installed. Very carefully have chosen Can Bus error message cancelation board in beaded, in each bulb , not the cheapest ones in the market. after I've seen erors messages on the rear one . Have installed 6 Ohm resistor , between ground and signal for each bulb stay inside the rear lump. I've find the wire harness on the floor of each side behind front seats, when take plastic covers . The only Turn signal bulbs managed to fix errors. "The running light off" I do not know even which bulb they are? Are those bulbs, that has two contacts on the bottom?; work when you push the Break pedal and rest of the night also flashing when vehicle running? or those with single contact. flashing all the time at night time in the upper rear lamps? i do not know , how to balance those to get read of errors? Any body done LED bulbs for License plate ? Any suggestions or tips, would help? Thank you! Igor.
1 - 1 of 1 Posts
