Yes!
I might have already blocked those off.. ahem
Yes!Go Flysurfer!! Where do you kite? Or do you snow kite? I think you'll have more room than you can imagine under the bed. I store 15 kites, 2 TTs, 2 surfboards, 2 foilboards, 4 foil setups, 8 wetsuits, harnesses, helmets, bars, etc. And stuff for living in the van full time.
I might have already blocked those off.. ahemMake sure you don’t permantly block access to those rear vented columns. There are important wires in there.
Yes, to change light bulbs, you first have to detach the taillight assembly from the inside.I might have already blocked those off.. ahemYou mean the channels going along the doors from top to bottom in the rear? I have stuffed them with rockwool, which is why I want to seal them off (blocking those airborne particles from the insulation into the living space). I've spray-glued a reflectix type of material on top all the way, and planned on a finish with fabric, but if I really needed to I guess I could cut it open to access the channel. What is the probability I would need to access those? Like, do I have to open them to change a lightbulb, or similar maintenance work?
Oh crap. Well, I then have to take that down and redesign it to be accessible in the future then. Thanks for the infoYes, to change light bulbs, you first have to detach the taillight assembly from the inside.
I gave it a go and redid the panel with some fabric. I'm not super happy with the result, so might redo it in the end to make the finish perfect. The holes for the screws were hard to get right.. (I attached a photo)Yes, to change light bulbs, you first have to detach the taillight assembly from the inside.
Absolutely. I just love when things are coming together and that I can actually see progress!Looks great! It’s so exciting when it starts looking more like a construction site and less like a van
I thought I ran out of connections to the busbar, but it might come down to poor design choises. I counted 6 needed connections, mind you not everything is connected just yet:Your last wiring photo shows 2 Victron Lynx Distributors. Is there a special reason for the second one?
I'll keep a note of that fuse number in case I'll ever need it, thanksInteresting. On most, that blank spot on the dash is a USB plug powered by a 7.5A fuse # F15 under the hood.
