1 - 20 of 23 Posts
2020 White 1500 LR 118" WB
Car salesman: So, may I ask what is the purpose of your purchasing a new ProMaster Van?
Me: Wanderlust I guess you could say!
Phase one construction on the new van was completed a short while ago - base rack support, extra long crossbars, and a kayak lift assist device. I am still thinking about mounting a roller to an additional 3rd crossbar at the rear of the van for the purpose of loading another kayak on top. Priorities right?
Items used:
Thule TracRac Van ES #29613XT
Thule ProBar Evo 200 (79") #713700
Thule Hullavator Pro #1685448
70650
70651
70652
2021, Promaster 159 HR 2500, Silver
Hey that is awesome! I have a couple of sea kayaks that I want to take along but I decided to go with a folding Oru kayak that can go in the garage. I don't have the kayak yet. I have a friend who has one and I'm waiting to get his opinion after a few months before I get one.
I think I want to save the roof space for solar and fans. But I do love your set up. That is a nice kayak!
I have always used Yakima racks and have a lot of components still. I will look at the Thule set up.
Where do you like to paddle?
-Paula
Discussion Starter · #3 · (Edited)
Phase two construction: Subfloor Install.
I installed Kilmat sound deadener to quiet things down a bit in the back, not that I felt it was extremely noisy - as I always have the music cranked up a bit. But I do have to say that this material is truly amazing. It really did a awesome job as for what it is marketed for. Since I am following the "No Build Build" path right now, here is the subfloor I settled upon: After cutting 1/2-inch birch plywood to fit, I coated the pieces with mold & mildew paint - with the general thought of all the water [lakes, rivers, and ocean] that I am constantly around. Once the wood cutouts were ready to be installed, I first laid down some foam underlayment to fit the floor dimensions. The plywood was then installed - where I then drove around for a few days performing a shakedown test ride. No movement, no banging, no nothing, so I was good to go.
I didn't want to lose out on getting ride of the tie-downs, so I drilled new holes and purchased #6 longer bolts - M8X1.25X50, to allow the tie-downs to comfortably fit on top of the plywood. Lastly, I replaced the factory rubber mat to be my surface. Overall this portion of the build was simple and sweet, yet very effective for my needs.
70653
70654
70655
70656
70657
Discussion Starter · #4 ·
-Paula
Hi Paula,
I am a sea kayaking instructor, so I paddle all over the place. Lately, I have been traveling up & down the east coast to various states for said purposes, and pleasure paddles too.
As for the solar panal & fan reference, I haven't looked that far ahead yet, but I do believe that there is enough room available up there for them.
That is the first kayak rack that made me think I could actually load them by myself on top of the van. Very nicely done. All of my paddling has been in Alaska except for a little in Maine. I'm hoping to get back to AK with my van this year but waiting to see what happens with covid (oh yeah and I have to actually finish my van!).
Love your build so far. Can't wait to see what is next!
Discussion Starter · #8 ·
The Thule Hullavator Pro is a wonderful device. It will help assist with up to 40lbs in weight when loading or unloading - depending on what type of kayak/material you are using. It definitely is a one person show operation. Everyone that I know that has one, or stumbled upon in similar situation, loves them. Such rack candy though comes with a price $$$, but after a few usages, the thought of how much money was spent quickly disappears.
Moving on, phase three of the build is next - lower panel design & install. Research ongoing as I type 🙂
Looking good! Save those extra down anchors if you have to remove them. I ended inserting some plus nuts in the roof of the C and D pillars and threaded the tie downs into them. Now I have some spots to run bungies and or paracord for hanging up wet clothing, etc to dry. One of those ah ha moments that I was really stoked on. LOL
Discussion Starter · #10 ·
Installed a bunch of cross nuts and hung some lower trim panels in the van in preparation for the construction of the bench/bed/storage boxes. First road trip is one month away and looking forward to it.
72098
72099
Discussion Starter · #12 ·
The frame out of the bench/bed/kitchenette/storage system is 98% done. This 3 part set-up is constructed to be held in place utilizing the shape of the van itself, as well as incorporating the usage of #5 of the floor tie downs. I wanted to have the option if need be, to fully remove all the pieces easily if required.
Hidden storage will hold all essential kayaking related gear, food & beverage supplies, and any other incidentals deemed necessary for travel.
The pull out kitchenette draw will be located in the rear box driver's side.
72422
72423
72425
Discussion Starter · #13 ·
Though the three components of boxes fit snug as a bug, I threw in a couple pieces of hardware to maintain unity amongst all parties. A couple of 1/2 inch bolts, washers, and wing nuts, and a few barrel locks did the trick. Each of these are easily accessible for dismantling and hidden out of view.
72462
72463
72464
You appear to have color-matched your panels to the cab. I matched to the white metal. I don’t understand why more people don’t color match when it is so easy to do. Yours looks really good. I agree with GSA that your cuts look perfect.
I am also impressed by your careful construction, but wonder why you chose 2x4. I see a huge amount of wasted space and extra weight. Everything you are building, you could do as well or better with vertical ply. if you used 3/4” ply, you could save a cubic foot of potential storage space (huge in the context of a van) for every 20” x 32” section.
Discussion Starter · #15 ·
I am not saying anything new that hasn't been said already, but the amount of information that I've gleaned from this forum, has been amazing. So many different ideas & builds to choose from = good stuff for Promaster owners!
@MsNomer, I used 2x4's simply out of strength and durability. I have an XL athletic frame - with a past history full of busted furniture, and I felt it best to have a solid foundation underneath me when sitting or laying down. As previously mentioned, when I am not out doing my kayaking thing, I can simply remove the sections for whatever other reasons. Now I am looking forward to applying all the finishing touches. And yes, I tried to match up and keep the continuity of trim color from the cab area in the back :)
Discussion Starter · #17 ·
Lots of smart work here. Any updates on this build?
@Slimvest , yes there has been a lot of progress with the build, but I've been busy traveling and teaching up and down the east coast pretty much every week. I'll post some updated pics soon I promise.
Discussion Starter · #19 ·
Very ingenious idea @Baxsie, similar to that sort of a traditional skin-on-frame build qajaq. Definitely a product that will serve those well who like to paddle, but don't have the storage space or rack transport capabilities.
Did you get an Oru? We have been looking at them.
Not yet. I am very busy working on subdividing land, selling house, building a cabin. Van build will probably pick up again soon because it may be interim housing between selling and building.
I do still want the oru kayak. My friend has been very happy with his. I have read some mixed reviews though. I don't think an inflatable would be better though.
Also interested in a folding electric bike.
If I sell my house it will be time to buy some toys!
Let me know if you get one or two and how you like it. I was looking at the bay model since I would mostly use it in Ocean.
1 - 20 of 23 Posts
