1 - 20 of 40 Posts
Just found out that the rear lights are switchable. You can turn them to an always "off" position. Or you can flip them to an always "on" position.......but they still go off after a period of time to save the battery.
Then there's the middle position that has them come on when the doors open. They go off after 5 minutes or so.
Seems like a good design.
Now if I can find a rear step bumper I will be happy.
They make step bumpers that go into a trailer receiver. Have one on my Sprinter. Had to shim it with big washers to make it stable though. Mine is full width. Not certain they make those anymore.
Got to love the power saving feature it has. The last thing you want is it being on and draining power when it's not needed
The light itself is the switch. It has 3 positions.
Although Sweet Tooth says this type of light is common my most recent vehicle was a 2000 E250. No switches like that on my Ford, so it's new to me.
I'm gonna add an LED light strip this weekend in order to brighten up the cargo area. Will put a timed switch on it so it goes off by itself after a time.
I was at Home Depot the other day and saw an LED under cabinet light and grabbed one. It runs off of 3 AA batteries. It has an adhesive back and also a magnet. I tried it and so far so good, so I picked up two more yesterday. I may eventually end up wiring in some strip lights but for now it's a simple solution to a problem!
Here's the link! http://www.homedepot.com/p/Commerci...r-LED-Round-Dragon-Puck-Light-72466/203682915
Discussion Starter #8
Sounds like a good idea. I paid over $90 for a 42" 12V strip of LED's. I hope it puts out enough light. If not, it's going back.
Can't wait till LED technology becomes more affordable. They say it coming.
Discussion Starter #11
That's a great light setup. Are the new lights wired into the existing lights?
I was going to just run a dedicated wire from the battery to a new timer switch for the light strip I have. Then I popped the lid off the battery in the floor in front of the driver's seat. Decided not to attach the wire there.......and then spent 15 minutes getting the lid back down where it goes......what a pain in the a**.
Sorry for the late reply.. lights are from Install Bay and are a standard type led strip.
For now i soldered them straight to the rear cargo dome light.
Oregonplumber, you may have a "interface block" by the passenger seat at the base of the "b" pillar. You'll find power there.
So far with nothing in it yes they're pretty bright. Only thing is that they're not sticking too well on the ends. I cleaned the surface and an adhesion promoter as well but they're lifting a bit.
Some plastic screw down clips would best to use as well.
Could someone please tell me how to view or open the attached thumbmails that people are adding to their posts
Thanks.
Thanks.
Kind of a pain but go to forum
go to general discussion
go to interior lights in cargo area
click the paperclip below the "rating" then click there
click on img 2369 jpg
I've been on many forums over the years and I have to say that this layout is pretty unfriendly.
I'm trying to figure how to view the pics as well and for the life I just haven't been able to do it.
The very best way (in my opinion) to put pictures is to upload them on an image hosting site, copy the image link and use the image icon on top of the editing window. I use "postimage.org", it's free and it's super user friendly.
The available saving space for images is fairly limited on this site, so sooner or later, one has to use an other alternative . So it's probably a good idea to go with an image hosting site to start with. By the way, most forums don't offer image hosting, so let's not be to hard on them, but I will check what's the problem on the test section.
Anyways, here's my led setup for my PM with it's custom made housing:
The problem: it's too bright!
1 - 20 of 40 Posts
