Keith - that's great info, thanks for posting!I use hoist rings on my VW, but they would be the same in a PM.
They are expensive, but they are load rated, and swivel for the load.
http://www.mcmaster.com/#hoist-rings/=vut28h
You can get D-rings for much much less, are stamped construction, but they have less of a load limit, usually half the strength for a given thread size:
http://www.mcmaster.com/#tie-down-d-rings/=vut77s
Awesome information, thanksI use hoist rings on my VW, but they would be the same in a PM.
For what its worth, I would not trust much load to the single nut welded to the thin sheet metal under the van with more than the current D-rings are rated (about 500lbs). I'd do some serious reinforcement before going so far as to put in something load rated...things are only as strong as the weakest link!I use hoist rings on my VW, but they would be the same in a PM.
