For most people, windows are a minor portion of their "envelope." For me, they are essentially the entire mid-height section. Not only are the windows themselves maximum size all around, but there is no "box" around them, as many have, so the entire recessed area is either glass, aluminum or bare steel.
Several years ago, I made coverings for the side windows from a cheap Walmart quilt with the fake glued-together "stitches." The primary use has been for blocking unavoidable bright lights at night. I decided that this year's winter project will be to upgrade them, but I like the look of the existing ones so well, I decided to improve them rather than start from scratch.
The windshield screen doubles as a barrier between cab and rear.
I have been using an identical one across the rear, but decided to upgrade to a quilt one. It wraps under the mattress and connects with the side curtain to insulate the living space not just from the rear windows, but from the entire rear area including the D-pillars. This is its first mock-up.
As you can see in the photograph, this quilt fabric is not blocking light very well, so I decided to add light-blocking fabric. As soon as the clerk handed me the folded fabric, I knew I could not use it on the rear curtain—its weight would pull the curtain off its magnets. It will work for the side curtains because they hang on hooks. For the rear, I bought the Class A sized version of the windshield cover and will attach the fabric with the shiny side out.
Sooo, I have three scenarios to test and compare if the cold weather lingers around long enough—quilt alone, quilt with heavy impervious white backing, and quilt with thin but reflective backing.
I have already determined that I can have at least a 25° differential across the original. (HF laser gun, surfaces taped per Gary's suggestion.) Given that I can practically see through it and a large percentage of its surface area is squished flat, this surprises me. Reflecting on the concurrent discussion of the R-value difference between Thinsulate and Polyiso, I wonder if the R-value of this fabric can even be measured. However, we both notice the substantial rush of cold air when it is removed.
More tomorrow, I hope. Any suggestions, @GaryBIS?
Amazon.com: EcoNour Car Windshield Sun Shade with Storage Pouch | Durable 240T Material Car Sun Visor for UV Rays and Sun Heat Protection | Car Interior Accessories for Sun Heat | X-Large (75 inches x 37 inches) : Automotive
Buy EcoNour Car Windshield Sun Shade with Storage Pouch | Durable 240T Material Car Sun Visor for UV Rays and Sun Heat Protection | Car Interior Accessories for Sun Heat | X-Large (75 inches x 37 inches): Windshield Sunshades - Amazon.com ✓ FREE DELIVERY possible on eligible purchases
www.amazon.com
