I have a 2017 136wb Promaster.
My key will only come out of the ignition if I attempt to take it out right away and don’t pause in the position between engine running and the key removal position.
To describe the problem another way…
Often when I park, I will turn the key one position counterclockwise to turn off the engine but not remove it right away. After some amount of time, I will turn it one more position counterclockwise when I am ready to get out of the van.
But the key will not come out in the key removal position. To get the key out, I have to turn it back clockwise one position to where the instrument lights come back on, and then immediately back to the key removal position and the key will come out normal.
Is this the way the Promaster is designed or is it something that should be fixed.
It seems like extra wear and tear on not only the key slot but also turning the ignition back onto the point where several components are energized is a bad long term idea.
If it is designed this way, can someone explain to me why they designed it this way, so I can feel better about having to go through these steps.
