Here is my “Alternator Charge Circuit”. All fuses & switches & pretty simple IMO;The original goal was to make the system as simple as possible. Having one switch that completely turns off the battery helps a lot with that. If there is a desire to switch off all loads while keeping the B2B/Solar charger combo on that is easy to do but IMO not necessary. It's all personal preference and how you want to use the system. The nice thing about the ON/OFF switch this way is that the LiFePO4's will be exactly where you left them if you turn the battery off and walk away from the van for 6 months. There is no need to charge the batteries in storage and Motor7's setup will go from 0% to 100% in 4 hours.
I use a Victron battery protect with the remote wires running to a small switch as my normal cutoff for all the 12v devices with the exception of the inverter. This lets me hit one switch and stop the 1/2 amp drain from the stuff I don't normally shut off like the Cerbo & Screen, USB chargers, etc. If you use that setup for $45 you also get a low voltage disconnect for everything in the van that will prevent tripping your BMS if you leave something on while the van is in the shade.
3 fuses & switches;
1) 4 position Blue Sea ,,, disconnect / charge both house & starter off 120vac converter / power to Parallax via house or starter battery alternator / can use the house as a jumper battery (I don’t)
2) Cyrix230 “electronic smart solenoid ,,, disconnects the starter battery under it’s factory set voltage readings “bidirectional”
3) Driver’s controlled ground switch to manually turn the Cyrix on or off.
So our standard “use” is;
storage mode Blue Sea is in the “OFF” position
Using the Van ,,, Blue Sea is on “1&2 or BOTH”. Then we turn the alternator charging ON or OFF from the Driver’s seat.
House AGM batteries are monitored on the iPhone via “Bluetooth” ,,, all upfront in the cockpit.
