1 - 2 of 2 Posts
Maybe the dealer will do this if you want to ask them next time youre in. I dont know if it would be a warranty isdue. Anyway. Buy a "add a circuit" with the mini fuses included. Then get under the dash and unplug the USB port. It's the big grey plug in the picture. Cut the white wire. Connect a 16 gauge wire to the short piece you left on the grey connector to the addacircuit. Find a 10 amp or less fuse in you fuse panel and put it in the addacircuit along with a 7.5 amp fuse which comes with the addacircuit. Then plug the addacircuit into the spot you removed the fuse from. Badaboom badabing.
1 - 2 of 2 Posts
