1 - 5 of 5 Posts
My house batterys will sit in front of the drivers side wheel arch. Where is the best place to ground these?
Is the rib in front of the wheel well a good grounding location?
Shane
I just used the existing tie down bolt in the floor to run a negative battery cable to the battery and also tied a grounding buss bar to the flange on the wheel well.
When you don’t have individual ground wires running to each circuit and/or you want to charge it from your alternator and only have the positive sides connected.
1 - 5 of 5 Posts
