1 - 6 of 6 Posts
2019 ProMaster 2500HR 159WB Window Van
As anyone here knows, you're first design may not be your best. I had a plan for my water tank placement, and then changed my mind for what I believe will be a better plan. Wait! I already drilled a hole in my poly tank and I need to move it. No problem, drill another hole. But what do I do with the hole I no longer need? Patching poly isn't easy. I don't believe there's a good, 100% no worry in the future glue to use. I'm thinking of some kind of expanding plug , just don't know where to look. Any ideas?
2018 136WB HR
hey Last Hurrah,
do you have inspection hatch in your tank? What about putting bulkhead with end cap? should work like a patch. Something like:
If there is no inspection hatch than Uniseal may work.
Just use whatever fitting you had planned to use and cap it off.
1 - 6 of 6 Posts
