I'm pretty new to electrical, and the learning curve is pretty steep. I've figured out a pretty solid wiring diagram, and now I'm moving on to understanding the smaller details of wire connections.
What is the best way to connect smaller gauge wire (22-18) coming from appliances (lights, fridge, pump, fan, etc. for example) to larger gauge duplex wire runs (14-10) coming from the switch panel/fuse box? Single crimp heat shrink butt splices? Double crimp butt splices with a piece of heat shrinking covering the connection? I would have to use step-down butt splices. Is there another mechanism besides step-down butt splices that will allow connection of differing gauge wire? Not sure the relative advantage of each, or whether another way of making these connections that is better.
Also, what's the best way to splice into a "run" of duplex wire? Say I wire a run along the ceiling for my 8 overhead lights. How do I splice into the +/- for each light and run more duplex wire along the ceiling to each light fixture?
Thanks!!
Thanks!!
