1 - 5 of 5 Posts
I have a factory partition with sliding window..
cab is fine with heat, but no idea for heat in the rear, to keep equipment warm..the old GMC van had the traditional metal slotted divider..so heat went everywhere..
here in new England it has been brutal for the last 3 weeks..
and aux remote hount heater ?
what has anyone else done ?
There have been a few threads on here where people have installed a heater under the passenger seat. You could duct it through the wall divider.
---> LarryK.
Care to elaborate on how the London unit works for you? The brochure seems a little ambiguous. Does this unit provide heat and cool, with the motor not running or does it only work when the vehicle is running?
Hi GapRunr. The Webasto London unit uses the existing heat and cold from the ProMaster. Basically an auxiliary heater core that tee's into the hot water lines and an auxiliary a/c evaporator that tee's into the freon lines. So yes, it only works when the Promaster is running. It has a heat/cool/fan/temperature control mounted in the dash in the little pocket just left of the steering column.
1 - 5 of 5 Posts
