So, I have read over threads in a variety of forums for building headliners.
I was prepared to use 1/16" ABS sheeting over thinsulate batting, then glue carpet or headliner fabric over the sheets, but, I am concerned about moisture accumulating behind the sheets.
So my question is this:
Could I insulate with thinsulate batts and use carpet alone to cover the ceiling and hold the batts in place without a structural surface? I'd use contact glue to attach the batts to the sheet metal. The carpet would be lightweight I/O, attached to the central ribs with a strip of ABS.
My only concern would be if the carpet sagged, so I have some ideas about how to pull the carpet tighter, possibly gluing the strips to the carpet or using some kind of tacking to gipo the carpet, then slotting the strips so they can be used to tension the carpet.
