1 - 3 of 3 Posts
My front right headlight has a leak that has continued to collect more and more moisture. My headlamp finally went out, and I am wondering weather I should just expect to replace the whole assembly. I haven't gotten into it to check it out, but this isn't the first leak issue I've had since owning it. I bought it used so I'm not looking for warranty advice. Has anyone had a similar issue with a leaking headlamp? Any advice on how to fix it? Thanks.
I'm putting a couple image links to show you the difference between my two headlights, as you can see, it is pretty bad.
https://imgur.com/btBTcoF
https://imgur.com/m3WsoIg
I've got the same thing. Both headlights get condensation in them after it rains and also winter time. One has been replaced just a few years ago. I think it's a mfr defect. Should be a recall on them.
I have just taken my headlight unit out to see why it is leaking and I can see that the moisture is sitting on the cover for one of the bulbs. The cover has an "o" ring to keep out the moisture but it hasn't worked. I will call my dealer in the morning to see if it is covered. Doubt it since they will say I didn't tighten it properly when I replaced the bulb. Its just bad design since the water actually drains onto the light unit and sits on the cover. I would like to bring it inside to dry it out. Does anyone know how to disconnect the wire harness from the unit. Seems to be a trick and I'd rather not break it.
1 - 3 of 3 Posts
