41 - 45 of 45 Posts
I have read quite a few insulation post on the forum and none speak to Havelock wool. Has anyone used it??? Is it worth the money over ridge foam. Thoughts???
While it might seem economical to use something other I'd refer you to Havelock's site on do the research.
Did you seall that up, or did you put that wool in there to help soak up all the water that the back tire flings in there?
I really wanted to insulate that area. It may not have helped a ton with insulation, but would have made a big dent in sound deadening.
After seeing that water gets in there,....even after figuring out how water gets in and sealing it, I still left it empty.
When it comes to water, all you can do is slow it down. I know better than to trust my seal job to last forever.
Unless you live in the Atacama desert, you shouldn't put any stuffing in that area.
41 - 45 of 45 Posts
