1 - 6 of 6 Posts
supposedly there is a service bulletin concerning grounding wires. I have a 2014 diesel and had been have the SEL light on and off, then the oil pressure light and various other warning lights. ALSO the issue of it NOT starting one day. I had read on here that someone else had the non start issue and it turned out to be grounding issues. THE DEALERS DONT ALWAY READ THE BULLETINS!!! so after getting the van back to the dealer it was purchased from (they actually drove 150 miles to switch it out) they removed the front facia and removed some ground wires and filed/scuffed the paint off. The paint was causing intermittent grounding.
The simplest one to check, and probably the most important is the main ground wire from the battery to a bolt in the chassis about 1 foot away. If you open the battery cover in the floor, the bolt is located where your right foot would be.
Worth a check!
I just updated my post with the grounding issue
http://www.promasterforum.com/forum/showthread.php?p=197753#post197753
One thing with ground problems it can show itself in strange ways
I have à starter trouble , it seem not ground
Is an other place that under driver floor that ground connect to the starter?
I Am able to activate the starter only if I connect ground to starter and bypass the Ignition swicht at the starter relay in the fuse box under the hood
1 - 6 of 6 Posts
