Hello all, I am letting my last class A diesel pusher motor home go, and will be searching for an extended 159wb 3500 Diesel, which I plan to convert to a fairly comfortable RV. I have owned enough (11) motor homes in the past to kinda know what works for us, and what doesn't, and hopefully, with the guidance of much more experienced and knowledgeable folks on this forum....I won't screw it up too bad.
I have a ton of questions, but I should start slowly, like, what year diesels are more troublesome? I will buy used if I can find one, but not sure where to look, Are diesels all 4 cylinder? I have owned diesels in the past, with very positive results, usually the only issues stem from the emissions controls which is a head scratcher at times, but usually simple to fix. (Not always cheap tho). Anyhow, Thank You all for any input you may pass along, looking forward to this undertaking. Regards!
