FS Passenger side CRL window $50
1131 3
Have a FW395R window FS.
See this page for full description:
The window was installed and subsequently removed for a CRL window without the opening vent.
The window is in very good condition except the foam tape around the inner frame it was damaged on removal. If you have the guts to rip a hole in your van and install one of these then you'll find it easy enough to replace the damaged foam with a new strip of sticky back foam.
This window installs with an inner clamp ring (included).
Please see pictures below. The drilled holes are for the clamp ring so are hidden when installed.
Asking $100. Must pick up (92122 San Diego) or can deliver within 30 miles of 92122. Cash only.
Automotive tire Hood Grille Building Automotive design
Automotive lighting Hood Automotive tire Window Motor vehicle
Hood Grille Wood Automotive tire Bumper
Green Azure Rectangle Wood Tints and shades
Green Hood Rectangle Blue Wood
Tire Grille Automotive tire Motor vehicle Automotive lighting
Grille Line Automotive exterior Gas Fixture
Plant Wood Textile Rectangle Shade
1 - 4 of 4 Posts
1 - 4 of 4 Posts
