Can any one recommend any good fog lights?
And also where would you put switch for it.
Factory fog light switch plugs into the existing wiring under the radio. This switch controls outputs/wiring at the BCM which in turn operates the fog lights. When I installed mine I couldn't find the wiring under the hood so I located the outputs from the BCM and ran my own wiring.
I believe the dealer billed me about $65 CDN or so to activate the factory switch and wiring. They did this at the same time they completed an oil change.. so maybe I got a deal.. not sure.
Did you happen to have the info on where the output is from the BCM ? thxFactory fog light switch plugs into the existing wiring under the radio. This switch controls outputs/wiring at the BCM which in turn operates the fog lights. When I installed mine I couldn't find the wiring under the hood so I located the outputs from the BCM and ran my own wiring.
