Window Install
As if cutting one hole wasn't enough. I decided to cut two more into the sides yesterday. They are Van Windows Direct Solid glass and look just like the stock windows. $140 each and you just glue them in. So let's start the project.
I used a cut off disk and an angle grinder to pry off the stiffener strut.
first hole and jigsaw tracks
I put three layers of blue tape around the window edges as I noticed only one layer of tape the jigsaw would wear though and start to scratch the paint. I also got this trick for the corners from some youtube channel. It worked perfectly. Highly recommend using hole saws. The drivers side window takes different sizes then the passenger side window.
This is my hack job before I tried the hole saw method. Kind of scary!
After the hole saw method.
The slider side corners are not as sharp so I skipped the hole saw and was able to make the turn with only using the jig saw.
My friend came over to hold the metal as I made the final cut. There was surprisingly little to file. I am glad I started with the drivers side first as that side less people will notice imperfections. My cuts around the passengers side turned out smoother. I applied primer to the bare metal edges. Waited 10 minutes to dry and then with a rubber mallet put the window trim on. Some parts of the van was thicker then other parts, just inconsistencies. I had to squeeze the two pieces of metal together with my fingers, but I managed to get the trim all around. The corners were the hardest part. The trim does show off how flat or not flat you made you cuts.
After the trim, apply primer around the window where you will put the adhesive. Let it dry for 10 minutes.
Next you apply the Urethane with a caulk gun. Man this stuff is thick. Now I know what people use the battery powered caulk guns. Cameron and I took turns applying the Urethane. You cut a V in the end of the Urethane tube so you get a nice thick bead.
Next I cleaned off the window with alcohol and microfiber to get a perfect bond. Two of us set the window in by placing the bottom first and just slowly putting it in. You can make micro adjustments to get it perfect, but we didn't really have to move it much at all. Once you have it where you want, One guy holds the window as I press in around all the sides to get a good seal. Then you tape it so it can't move.
Wrap up:
So the project took 6 hours. Next time it would take 2 hours. I had to get a longer 5" jigsaw blade because my 3 3/8" metal blade was not long enough and kept popping out, scratching and making dents. I could only find a wood/metal blade in a longer length and that worked OK, but I would have rather gotten a longer metal blade. Maybe one can find that on amazon. It would have made the cuts smoother. Also, the battery caulk gun would be nice. All in all, I'm stoked how it turned out. Van Windows Direct are super behind right now. These windows took 2 1/2 months to come in, and my CLR 10" X 33" awning window for over the bed still hasn't arrived. (It shipped yesterday.) So I still have one more window to put in. Then I'm done making big holes.
I still have to cut in the van for the Isotherm Hot water tank and the Wabasco heater.
