The story:
My other PM and driver were heading to a pickup. CEL came on 50 miles from destination. He's new and doesn't carry a code reader, so I advised him to keep driving. 5 miles from pickup the low oil pressure warning came on! Yowsa. He gets there, and sees that the entire back and bottom of the PM is covered in oil. We call another truck to handle the load.
I put the kids with a babysitter, and race out there to see what can be done. The code read "camshaft B position disagree" or something like that. It drinks 4 qts of oil and then it's good on the stick. I limp it to a Ram dealer, luckily only 3 miles away. It makes an oil slick all the way there, but the motor is fine.
I take an educated guess that it's an oil leak relating to the oil cooler. Pressurized oil is leaking, and since the cam phasers run on oil pressure, they can't track right. I guess it's not a cracked head, cracked block, or blown head gasket.
Dealer takes 4 friggin' days to get around to looking at it, but when he does he determines that the oil cooler has cracked. It's located in the V of the engine, and it forms the housing for the oil filter canister. Apparently, it exchanges heat with the coolant, so it's more of an oil warmer than an oil cooler. Dealer says that it's a common problem.
Common? I never heard of it. So I go digging. I find on a Jeep board that yeah, it was super common for the first run of 2014 Jeeps. Those were all failing at very low miles, but mine is at 96k. Mine is a super early build, I wanna say October of 13. From what I gather, the part is about $150 and it's 3-4 hours to install because the upper and lower manifold have to come out.
I'll have a written estimate next week, so I'll know the exact amounts. I'll try and get a VIN sequence out of them since I know some of you guys have early builds as well. It took FCA a few months, but they fixed the cracked coolers under warranty and they revised that part, so I doubt newer ones have the problem.
If you get a CEL and can't read the code, it behooves you to pull over and look at the back of the block on the drivers side. If it's drenched in oil, you know what you've got. Failure to stop will drain the pan in fairly short order, and I felt pretty lucky that we didn't blow the motor or spin a bearing. The Jeep guys tape a q-tip to a coat hanger, and run it into the V from the oil filter housing to check to see if there's any puddling that might be a tell tale.
I'll keep you posted.
