1 - 12 of 12 Posts
Fiat Professional will show "Fiat Ducato 4x4 Expedition" (RV show vehicle) at next Caravan Salon in Düsseldorf (Germany).
4x4 system, visco-coupled + self locking rear differential, is from Dangel, and it is only available with 2.3 diesel engine.
Fiat Professional press release (for now only in italian)
http://www.abarthpress.com/press/article/117161
technical sheet (in italian)
http://www.abarthpress.com/actionphp/download.php?id_brand=5&id_content=117161&filename=2015%2FFiat-Professional%2FSchede-Tecniche%2F150828_Fiat-Professional_Ducato-Camper-Van-Scheda-Tecnica_ITA.pdf&type=attach&subtype=price
Really?....
Great looking conversion...
Not trying to sound cocky, but those roads looked pretty tame. I wouldn't be afraid to drive any of those roads with a two wheel drive... Here is our camping spot on a gravel bar in the middle of a river last weekend, (decided we should leave in the morning after it had rained several hours and we noticed the river level rising... :) )
I don't own a promaster yet, but I'm betting a two wheel drive could have done all those roads..
I'm not one for the 4x4 vans, and those were fairly tame roads, but... oh, yes please. And that looks way better (IMO) than the Sprinter 4x4.
Nice picture Scott B!
Sprinter sits high. (4 inches?)Then the stock height? 108 +4 = 112? I imagine this 4x4 will go a lot farther then ours despite the video.
Looks like the Ducato is not jacked up.
Thanks for posting MJAB.
I like it! The Dangel system has been posted on here before... quite interesting.
If there was a easy way to open up the wheel-wells to take a bit bigger tire it would look really nice.
I've already driven my Promaster into more challenging terrain than that video! I would be interested in 4wd since its winter here about 6 months a year. FWD is okay but 4wd is better. Keeping it relatively low improves winter handling as well.
Dangle has a couple different ways to transfer power from a FWD, this one seems interesting:
"For a heavier duty application, the Peugeot Boxer High Mobility HM3 (Haute Mobilite, below left), the original transmission is entirely discarded. The engine remains in its original transverse mounting but a bevel gear and shaft take the drive rear-wards from the clutch output.
A new transmission is mounted in the centre of the van and drives the front wheels (with independent suspension) and the rear wheels (with a live axle) by propeller shafts. The gearbox is a very neat, flat unit and houses a 5-speed gearbox, high-ratio (1:1?) and low-ratio (2.1:1) reduction gears, and a lockable centre center --> differential. A dozen other applications for this neat box spring immediately to mind."
1 - 12 of 12 Posts
