Any ideas for a exposed sound deadening product I can use without it being toxic or floating tons of fibers into the air? If it has a modicum of insulating properties that'll be fine. I'm going to bond some of that denim insulating stuff with spray contact cement to the sides before I put my Penda panels up but need something for the ceiling that will remain exposed. I'm trying to cut down on the echo or reverb effect of the space.
Until I figure out a partition solution I want to cut down on the noise, and if it reduces the heat or cold transmission as a benefit that'll be fine too.
