1 - 8 of 8 Posts
If your fans are running at full speed and are really loud, the resistors are bad. Mine sounded like a 747 taking off. Changed out the resistors and now they are back to normal. Easy fix too. Also if you smell coolant and don't see a leak, check your coolant recovery tank. Mine had cracks on the bottom, and it would seep out. Most likely from being hot and cold and being pressurized. Hope this helps!!
58350
58351
I actually bought the whole fan assembly off eBay for around $142. I was going to change out the whole thing when I read somewhere that most likely the resistors were bad. So I took the new ones and changed them out. So I don't have any part numbers. I'm guessing you can get them online somewhere. Hope this helps.
1 - 8 of 8 Posts
