First and foremost I'd like to thank KeepOnVaning and ProEddie for their generosity and wisdom. They have assisted by giving me some tools that I have applied to gain the knowledge I'm about to share with you.
The Ram Body Builder's ProMaster Electrical Schematics can be found HERE. You will need MS Internet Explorer to use them.
In the example below, you will need to navigate to Bookmark 28, Internal Lights. Look closely at the "Splice S0001-DIMMING LIGHT" and you will notice "E3 .35 YL/GY" above one of the lines. The line represents a "wire". This is a Yellow wire with a Grey stripe (YL/GY). This is the "dimmer" (DIM) output for the radio, gauges, etc., circuit E3. The wire is .35 inches in diameter. If you follow circuit E3 out to the margin, you will see E3A / [9:A4]. The 9 represents Bookmark 9, location A4.
On the right side of the PDF window, you will see the "Table of Contents". Scroll down (or up) until you reach bookmark 9, "Entertainment", and click on it. In location A4, you will find circuit E3A! (You will also notice that it cross references back to Bookmark 28, Internal Lights, Location F1!) You can follow this to connector D3843A, the RADIO SPARE, and you will see that it is connected to the # A6 pin on this connector.
You can use this method for each drawing, circuit, and connector in this manual. It felt really good to solve this riddle and I hope this helps everyone! Cheers!
OTHER HELPFUL INFO:
DG = dark green, RD = red, WT = white, BK = black, YL = yellow, OR = orange, GY = grey, DB = dark blue, BR = brown, VT = violet (purple?), TN = tan
OTHER HELPFUL INFO:
