When you say starting problems, what exactly is happening? How often are you experiencing the problem? Starts only sometimes and flashes those errors when it doesn't?
Does the engine fire up and then die? Or is it just cranking without firing up? Or does it not even crank, and nothing happens when you turn the key? Do you have remote start where you start the engine from your key fob?
