1 - 20 of 31 Posts
Hello and I just want to say how awesome this forum is and especially the detailed information on here!
I’m working on our Promaster layout, electric and plumbing, and when that’s done, my partner will take over the actual construction, since he has quite a bit of experience with that.
I think I’m pretty close to something of value, but would really appreciate any input, observations and ideas so I can wrap this up and move on to the plumbing. Wheee.
Note: Our 2019 PM is a 159” high roof in a dark granite grey. My partner and I have named it Grey Matter ;), and I even made a page for it on my art website so people can follow along as we make a part time home for our hiking and travels. We decided we have the time and energy to do this project, rather than pay more for a lesser quality result.
A couple of items on our wish list:
- some solar, we probably would be off grid 3 days, longer if possible.
- probably propane for cooking and a water heater
- shower and portapotty were my must-haves
- a 12v fridge
- microwave (for reheating only)
- electric water pump
- we want to leave room on the roof for a (tiny) deck up there. That means only two solar panels, a maxx air fan and a future air conditioner up top. (it’s possible the future air conditioner will be shore power only)
Here’s my diagram so far- (attached)
Thanks in advance for helping us move from paper dreams to actual road time!
Electrical
- a 12v fridge
Hi Artbybam
I took a brief look. Im no expert & you will probably get more ideas/opinions here. Here are my thoughts
The Victron battery monitor gauge with have a shunt (battery side & “in my case ground to chassis”). Without a “common” ground (I used the chassis) you cant complete the circuit for the battery isolator ARC
The Victron Battery Monitor with bluetooth is a nice feature to get the info on your phone & also to setup
Im not familiar with much of the equipment you have choose. I can tell you I bought a charger/ac panel/dc panel all in one box.
http://parallaxpower.com/power-centers/
Have fun with “Grey Matter”
I see that detail in the Victron install guide. I didn’t show the complete connections for the Victron or the other monitors. Plan to show with more detail later.
The parallaxpower center looks like a nice option! I’ll check it out further.
Thanks RV8R!
These kind of visual diagrams are so helpful for my inner artist that likes “pictures”. :D
Hope to have my next electric layout look more like this.
Thanks!
A Photo of My Install
I dont have a good photo handy of my install, but attached is an earlier photo before I “tidied up” the install
I will try to describe some of the runs here briefly;
Promaster Engine Alternator Charging;
existing 70Amp fuse on starter battery to Victron Battery Combiner (in photo) to switch
Positive House Battery (in photo) Red;
Battery post to 200amp fuse on battery post to switch
Negative House Battery (in photo) Black;
Battery post to “battery side” of the Victron BM shunt / other side of the shunt to ground “chassis”
Other Wiring Methods of My System;
1) The Manual switch has 4 functions; All Off / House Battery On Only / Started Battery On Only / Both House & Started Batteries On
2) The Manual switch has 3 lugs; battery lug 1 / battery lug 2 / load (which goes to my positive charge bus)
3) My Positive Charge bus has a 30amp fuse & then the positive red wire to my DC Panel
4) I used the “Ground Side” of my Victron Shunt as my Negative Charge Bus (I only have a couple of rings on it so I did not worry about an individual Negative Charge Bus)
Bus / Bus Cover / Battery Fuse Holder / Battery Fuse; All Marine Grade “Blue Sea”
All my wire is marine grade “corrosion resistant”
Some of the items & quality of the parts is not necessary. For me I look at the cost benefit & make decisions - I even get some of the decisions correct in my mind.
I tend to “over build” as a method of insurance (real or false one either finds out or never does). I try to have 360’ forethought, but have many blind spots.
You will get loads & loads of information on this forum (we all have opinions).
If I ever build another van (& I intend to as I am going to use up & mile out my 2018 as fas as I can), I could literally build it in 1/3rd of the time I took (which in my case was about 5 or 6 months in my spare time “part time”). Research & Understanding is the key. Don't be afraid of mistakes as we all DIYers make them (heck the Professionals all make them & the good Professionals are expert @ hiding their errors)
IMO one of the biggest advantages of DIY is the knowledge you have once you have completed (btw you never are completed)>:D
Welcome to this Wonderful Sharing Community & All My Best to You for Your Buildout !!
I re-read your design parameters;
I really think you would benefit from reviewing SteveSS build of “Shiny’s” buildout
I have personally seen “Shiny” recently as Steve & I live in the same city
Steve has lots of RV experience & has done a fantastic job of design & build. If I wanted a shower I would really consider his design, as once I saw it in person it made a lot of sense to me. Steve is also a very helpful guy & very humble
https://www.promasterforum.com/forum/showthread.php?t=61554
Check it out if you have time
Energy Management - My Biggest Mistake(s)
- a 12v fridge
- we want to leave room on the roof for a (tiny) deck up there. That means only two solar panels, a maxx air fan and a future air conditioner up top. (it’s possible the future air conditioner will be shore power only!
One of My Biggest Mistakes in My Build; Was not understanding Energy Management. If I were to do it again I would separate my Needs/Wants into the following categories & solve the “Energy Management Requirements”
The Type of Energy & the Storage Tank; The house batteries are just a storage tank that you can only use a percentage of to get longterm use:eek:
Energy Tanks; House Batteries / Propane / Diesel / Gasoline / Other ?
btw your PM most likely has a aux fuel pickup already in your factory tank
All Energy Tanks have pros & cons. I prefer propane tanks to be outside the van, but have not come across a magic solution to my “want/preference”
Electrical;
12 volt (easy & I made everything 12volt that I could - I also have a converter not an inverter. A converter takes 120v shore power & converts it to 12 v)
120 volt (IF inverted from 12v batteries “very expensive & need loads of battery power if using inverters to “heat” or “cool” ) 2000W of 120v from a 12v battery (take the W divide by 10 to be safe) = 200amps :eek: btw it does not exactly work like that & some here may fault me for providing a overly simplified formula that is not accurate, however 12v inverted to 120v depending on the “efficiency” of the inverter, blaa, blaa, blaa you are going to need a huge battery bank & ability to “fill the tank”. I finally realized this too late in my build & the scene from “Jaws” came to my mind - You Are Gonna Need a Bigger Boat”
Something I am considering for Hot Water;
The Isotherm Spa Hot Water Tank; This uses heat from your engine to heat the hot water & also has a 700W 120v electric heating element. Again, check out SteveSS Shiny buildout
Conclusion; Energy Management & Design - Very Important
Discussion Starter #9
Appreciate the image and detailed info with it. I’ll sit down and see what I can absorb.
We do want to overbuild, as well as do it correctly. Although we are getting a bit antsy to get started on the “good stuff”.
I know, patience and planning pay off!
I did find some info on the fuel tank aux pickup. That makes me reconsider a webasto heater, for 12v usage.
Thanks for the welcome! There’s lots of good people on here and I’m looking forward to finding out how much I don’t know!
Discussion Starter #10
On it! With so much good info on here, it gets a little challenging to know which ones are helpful at the stage we’re at.
Thanks!
Discussion Starter #11
Electrical;
Same here for the propane. We’ll probably start with the butane or small propane one burner for cooking.
Great - now I’ll research converter vs inverter!:nerd:
Hot water - also looking at options.
So many decisions to make, so that the ‘bigger boat’ isn’t needed!
A couple points - I probably bit off more than we needed for our first one. But hey, go big or go home? :D
Think we’ll take it out for a few days before we get too far along and see if it’s going to work per the plan.
I’m off to check out SteveSS.
Converters and Inverters are completely different things.
Most converters do several jobs and make installing a complete electrical system easier. They have been around in the RV world for perhaps 50 years but new ones are much more sophisticated.
First they take a 120 volt input (through a breaker) that can serve appliances and outlets when plugged in to shore power.
Second they have spaces for several breakers to make the output safe.
Third they have a power supply that can charge the batteries, new ones can handle most battery types.
Fourth they accept power from the batteries (and power supply if plugged in) and feed that through a set of 12 volt fuses to safely supply your 12 volt needs.
Fifth they allow for proper grounding of the shore power- this is not a trivial issue.
These things are very inexpensive for what they do, are super reliable, and compact. They generally do not invert 12 volt dc to 120 volt ac. That is an inverter.
Here is my converter. 30 amps should cover you even if you run an AC on the shore power.
https://smile.amazon.com/WFCO-Arterra-WF-8712-P-Trailer-Electrical/dp/B00MJVSANW/ref=sr_1_27?keywords=RV+converter&qid=1560704020&s=gateway&sr=8-27
Here is my inverter.
Very Helpful RD
I went that route, as after I looked at the space of a dc panel, ac panel, charger/converter it make sense to me
It is typically what RVs use;
Mine is per the following link ( Canadian Amazon - not USD )
[ame]https://www.amazon.ca/Parallax-Power-Supply-Converter-Charger/dp/B00JPJTDI2[/ame]
RD is spot on with regarding to the A/C power “grounding”. Not to be confused with the DC chassis ground
The A/C grounding is tied into your “shore plug” right back to the “shore panel system” (ie not your Van, but the campsite electrical plug)
The panel I bought & most likely RDs utilizes “house breakers” that you can purchase @ a hardware store. I like to stay with mainstream off the self items if I can as they are usually proven, available on vacation, & proven in everyday life in houses without wheels, and competitively priced due to Supply & Demand not specialty industry
Very Good Points; RD made for the use of a “converter/charger/ac panel /dc panel unit.:D:D
I would like to tell you I picked up that advice on the forum, but I did not. I got mine from a very experienced retired electrician friend of mine, who just politely got me on track (think 180 degree turn) with his kind persistent nature & patience. I was lucky to have such a friend, thus Im trying to help out here with the things I have picked up during my build
If I wanted a shower I would really consider his design, as once I saw it in person it made a lot of sense to me. Steve is also a very helpful guy & very humble.
Thanks, RV8R. Yes, no one is more humble than me0:)>:D
Shiny's basic design reflects our own personal experience and priorities. Everyone's are different. The central, pass-through shower is fairly unique for RV's, but not small boats (pocket cruisers short on space). I approached construction based on my experience building small plywood boats sheathed in epoxy and fiberglass. There are much simpler and quicker ways to get a shower, but I had those skills and enjoyed the challenge.
Discussion Starter #15
Converters and Inverters are complete different things.
These things are very inexpensive for what they do, are super reliable, and compact. They generally do not invert 12 volt dc to 120 volt ac. That is an inverter:
Thanks for simplifying. I think!
So, an inverter/ charger doesn’t do the same job as a converter?
You have both an inverter and a converter?
(I think you sent me the same link for converter and inverter.)
Discussion Starter #16
Electricians are good to know!
Just as I thought I was getting the hang of it, I realize I’m not there yet. With all my research, I find people call the same equipment by different names!
But I’m very motivated, and haven’t given up.
I do have an electrician friend who is quite busy with other projects right now (in spite of me explaining how important Grey Matter is, haha). Hope to get his input in person.
Guys, thanks again. I’m off to regroup and redo my plan. :)
Discussion Starter #17
Took a look through and your build thread is great! Very creative shower layout, and great build information.
Thanks! :)
I fixed the link I believe. Sorry to confuse.
No they do different jobs, I do have both.
Lastly there are a lot of quotes for responses following the quoted text. I can fix my bad link but I cannot fix the quoted links..... sorry.
There is another common approach to electrical systems in RV that you might want to look into. This uses and Inverter/Charger in combination with a power center (fuse box).
The Inverter/Charger combines and inverter and a battery charger in one unit. When you are not hooked to shore power, the inverter produces 120 volt AC power from your battery, and when you plug in shore power, the Inverter/Charger switches to shore power for your 120 AC, and turns on the charger part to charge your batteries off shore power.
One nice thing about the inverter charger is that it automatically takes care of the issue of bonding the AC neutral wire to the ground wire at the correct point. For safety reasons, the AC neutral wire and the ground should be bonded together at only one point. When on shore power, the bonding point is back in the campground wiring system, but when you are on battery power, the bond point is inside the RV near the inverter. The Inverter/Charger has a built in relay that automatically accomplishes this.
Diagram of a system (mine) that uses an Inverter/Charger setup: https://www.buildagreenrv.com/our-conversion/promaster-diy-camper-van-conversion-electrical-and-solar/
Discussion Starter #20
Thanks Gary, I had your site saved in my bookmarks already! Looking over your nicely labeled photos of actual construction.
I do plan to use an inverter/charger, pure sine wave, not sure if the ones I’m looking at come with the fuse box.
1 - 20 of 31 Posts
