Have some questions about experience with an electric water heater. As we were talking about hot showers in another thread, I had a thought about using something made for this vs my current method of using the electric kettle.
Eccotemp makes a nice small portable 2.5 gallon electric water heater. It has a 1400 Watt heating element and according to them, it takes ~13 mins to heat up 2.5 gallons from 60 degrees to 125 degrees, which seems perfect for a shower, or using it to wash your hands/face with warm water. It would be really easy to plumb it up. I've got the space for it behind my water tank, and I could run the hot water to the faucet as well as the outdoor shower.
I've got 400Ah of batteries, so I should be able to handle this no problem, and technically it shouldn't take THAT much more power than my 1200 Watt electric kettle takes to heat up 1/2 gallon of water to 220 degrees. I think my normal use case for this would be to run this water heater while I'm driving and while the alternator is supplying 20Ah+ to my batteries. Maybe even insulate it further than it currently is, so it can hold the 125 degree water for quite a few hours.
Link: https://www.eccotemp.com/eccotemp-em-2-5-electric-mini-tank-water-heater/
Anyone used something like this?
edit: Also a possible option is this $400 12V DC unit. With a 300w heater element, but powered by DC, this would be a LOT more efficient. Also states that it will hold the hot water for 10 hours. Add a layer of insulation over the top and I bet that would be even longer: http://www.defender.com/product.jsp...-gallon&path=-1|51|2234308|2234310&id=2785571
edit2: MOAR googling and I did find a reasonably priced engine coolant driven unit with 4 gallon capacity. While that's bigger than I wanted, it seems this would be the ultimate way to go. As this would be heat the water while driving, for free, and it's reported that it stays warm for 12-15 hours: http://www.isotherm-parts.com/index.php?main_page=product_info&cPath=4_34_107&products_id=1986. Guess this could get mounted somewhere underneath the van maybe vs running engine coolant lines inside.....
edit3: Another 12V unit here. This one is like $500, but seems definitely targeted for campers/vans: https://www.truma.com/int/en/products/truma-water-systems/truma-electric-water-heater-boiler.html Here is an install in a camper van: https://campervanconverts.com/tag/truma-electric-boiler/
