Yesterday I attempted to start hooking up the electrical system in my van, and I have run into a road block at the first step. Hoping someone in this forum with more electrical experience can tell me where I have gone wrong.
Specs:
We have a Renogy 12V 50A DC-DC charge controller with MPPT (part DCC50S). I connected the starter battery to the charge controller with 4AWG wire (Renogy's recommendation). I have the input charge running through a 80A breaker to serve as overload protection & cutoff switch. The output from the charge controller then runs through a 60A ANL fuse to our battery bank (2 100AH Li batteries). When we turned everything on to test everything works as expected for 2-3 mins then the breaker trips. Any ideas what I have done wrong? I don't see where the system could be shorting, but I am also not really sure how to troubleshoot this sort of electrical issue. I did notice all the other draws on the starter battery are fused, is where I tapped onto the starter causing the problem? The other possibility I thought of is that voltage drop is causing the issue since the wire run is pretty long (~20 feet), but given that this is a 50A controller I wouldn't expect the draw to be anywhere near 80A (right?).
See photos below
Specs:
See photos below
