1 - 2 of 2 Posts
Hi All! Just got a used PMC. All good so far BUT have noticed that at 70+ MPH I get interior wind noise from the driver door. As if the door wasn't fully closed. Quiet at lower speeds. Rubber strip on door "appears " to be OK. Window fully up. Anyone else gotten this? Fix? Any insight appreciated. Thanks. TD
Discussion Starter #2
Problem Solved - Found the loop in the door frame loose so the door latch was never far in enough which left a gap on the outside of door. Used Torx bit to tighten up the loop and Voila! Door is now tight.
1 - 2 of 2 Posts
