Has anyone tried to install the OEM windows of the 159WB window van in the 136WB model? I haven't seen any window vans yet, but in looking at the basic panel-van, the sheet-metal appears recessed in the area where a window would be, such that, if the center of each region were cut out smartly, one might be able to simply bond the glass to what is left. This idea seems further supported when looking at a panel-van with the glass-equipped side sliding door. On close inspection, you can see the surface of the glass is proud of the sheet-metal surface behind it (where I am proposing to cut out for the window). On the driver's side, one would have to cut out two openings.
Without yet looking at a proper factory window-van (I believe they are just now starting to trickle into dealer lots), one question I have is how different (if at all) is the reinforcing structure behind the external sheet-metal. This might give some insight into whether this idea is viable, or I am just dreaming.
Also, this idea assumes that the glass is available for purchase at a RAM dealer's parts counter, and its cost is not prohibitive. It might take a few years before window vans show in in dismantling yards, from which to harvest used glass.
I'm intrigued by the idea of using an OEM-type approach, because I simply hate those universal-fit, cut-a-hole-and-clamp-it-in, style of windows used by many van and RV conversion companies. They never seem to fit right, and consequently look like sh*t, in my opinion. Or better yet, why doesn't RAM offer a window-van for order in more than just one size of van?
If anyone has any experience with this or other ideas, please share.
Thanks,
Chris
Thanks,
Chris
