1 - 9 of 9 Posts
I have been playing around with my new PM for the past few days now. I have found out almost everything about the controls, except for these two.
1 - Can you and if so how do you adjust the brightness of the dash lights?
2 - As for the system that tells you when to change the oil. Is there someplace that tells you how far you have to go before you need an oil change? I don't want to head out on a long trip, only to find out some fifty miles into it that its time to change my oil.
MIL (malfunction indicator lite) came on this morning. Manual says my shut off after a few regular driving cycles. Anyone else have this happen? If so what did you do to correct? 2500 with 64,000 miles.
The dimmer is controlled by the two up/down arrow buttons to the left of the steering column.
I haven't discovered the other feature you asked about.
Go to any auto parts store and get a code scanner that will tell you what the problem is. Could be stupid, could be something you really want to fix.
1 - 9 of 9 Posts
