I would like the two 12 volt power supply ports located in front of the single cup holder below the radio to always be powered even if the ignition switch is off. I'm thinking that they are operated using a relay to trigger power to them when the ignition switch is turned on. So if I could locate the relay and replace it with a jumper wire then power should stay on, what do ya think, will this work? And does anyone know where the relay would be located? I opened the relay box in the engine compartment hoping that things would be labeled but they are not. There are coresponding location numbers for everything but that doesn't help.
Thanks much for any and all insight on this!
