1 - 19 of 19 Posts
Read Only
I already bought it and it has been sitting in its box in the foyer waiting for me to give it some love ;)
To the OP, Yes, I believe any larger and it will interfere with the vans ribbed roof.
Read Only
I finally got around to installing the sunroof that Eddie sold me. Midway through the installation, I developed a massive migraine. I kept pressing on as daylight was getting short. Nonetheless, it turned out absolutely perfect. My wife spent the next hour massaging my head after I took two Tylenol and two Excedrin.
Anywhoo, Thanks Ed!! This brings in some light and air to the otherwise dark space.
IMG_2357 by, on Flickr
IMG_2356 by , on Flickr
IMG_2355 by , on Flickr
I have this sunroof installed in my van. Its really nice but the tinted glass gets really hot in the summer and can heat up the inside of the van. Maybe I should put that white vinyl @phil turned us onto
on it?
Im not sure if everyone knows this but its made so that the glass is easily removable. The glass pops off the hinges using a nice system and in about 30 seconds I can easily remove the whole glass panel. Pretty neat if you want to drive down the road with the windows open or want access to the roof from the inside of the van... I intend to make a screen for the inside so i can leave the glass out in the summer.
2016 136 HT Gasser
I have one of those CRL's, too. My overhead "decor" is a sheet held up with magnets, much prettier than the insulation! I have a flap of the sheet which I can extend over the sunroof, it mitigates a little of the heat. With 1" polyiso on the overhead and sides, the cab windows open and the sunroof open and shaded with the sheet, I've not had the interior temp go above ambient in 80F conditions. And yes, that's the right size for the flat spot on the PM. Also, while the roof is slightly contured and the sunroof frame is flat, there are so many screws sandwiching the inner and outer frames together that they bend to conform to the roof contour. The thick seal for the glass panel (also flat) mitigates leaks. I've had mine for over a year and it has both stood and been driven in pouring rain without a drop coming through. Water can pool in a corner of the glass panel but its less than an ounce. I have a bit of clean rag stuffed in the panel handle to catch any drips. I keep the glass and seal clean, it is easy to pop the whole glass panel out to clean. Oh yeah, after installation give the exterior, especially the roof, a good scrub. I was amazed by the number of tiny flecks of rust that appeared even after what I thought was a sufficient hosing down.
Discussion Starter · #13 ·
looks great... I‘m waiting for mine to arrive. Does it come with instructions and did you have add sealant and if so what brand? Would a jigsaw be the best tool to cut the hole. Thanks !
Read Only
No sealant needed, came with instructions and template. It comes with butyl sealant and its tricky to install so take your time so you don't get it stuck into a bad position. The jigsaw worked best since I cut it from the topside. (Put a drop cloth on the inside as the metal filings get everywhere.) The template might make your cut a little small, but you can keep slightly trimming once you set the frame on the opening to see how much. I put wide blue tape around the cutout before putting the paper template on to trace out the hole and protect the paint from scratching with the jigsaw. (My jigsaw already has a nice plastic bottom but you never know ;))
Discussion Starter · #15 ·
Thank you, I appreciate your reply
Banned
I would like to install the same sunroof in my 2500 PM. Other than the migraine (sorry to hear about that) was the install difficult? I am fairly handy, but curious what you used to cut out the sheet metal roof -rotozip, jigsaw? Thanks for any insight you can provide.
-Eric
Banned
Please be aware that all newly registered members MUST make an introductory post in the Introductory Post Forum as per forum rules. Promasterforum.com Introduction Section
Do you have a link to buy this?
Nick
1 - 19 of 19 Posts
