I just am in the process of installing my T-vent CRL window on my passenger sliding door.
With the hole cut, my window fits in nicely (I think), as when it's inserted and pushed against the van wall the rubber window gasket is against the van skin all the way around. Additionally, from the inside there is between 1 and 3mm of rubber showing inside of the cut van skin, and thus I know the window is in as far as it can be.
I haven't used the mounting ring to 'suck in' the window yet, but pushing on the window to mimic the mounting ring this is my question: Is it normal for the window to stick out quite a bit? For some reason I had the idea of it being more flush, perhaps that the rubber seal gasket would be thinner or something. As long as the rubber is against the van skin all the way around, I'm ready to screw down the clamp/mounting ring correct?
If anyone has a close-up image of their CRL T-vent (or non T) mounted on their sliding door, it would be really helpful to see a close side profile so I can see how much relief the window has off the door. By the way-the bottom of the window with the T opening lines up well side to side, I saw some posts about this but it looks like mine is fine.
Appreciate any help.
Kipp
Kipp
