I will be picking up my diesel high roof 136" this week and I'm thinking through the up fitting options. I'm just trying to see what you all did and what was important in a few areas, and if you had it to do over again would you do it differently.
- Partition: did you install a fixed one or one with a door so you could access the back. My though is if I have a door I can open it and run some longer stock into the cab area, I'd be able to get 12' material in that way. It will come with a rack (and roller bar on the back...sweet!) for 16's which is what I primarily get but getting to a rack that high is going to be a major PItA so if I can shove some other stock inside it'll be that much easier. Also, was ingress egress to the cargo area important in your decision?
- Cab desk thing: Do you have one of those cab desk/cabinet things that goes between the two front seats? I think it would be pretty handy for writing on which I do quite a bit in my current truck. Of course that would negate the need for a partition for the door and I could go fixed.
- Sliding door window: This van did not have this option, although for about $500 I can have one cut in, there are kits for this that glass people have, it's not supposed to be uncommon and the dealer told me it's no problem for an up fitter. Is this something you really use/necessary? I'm sure I'll find out after some seat time but just curious.
- Any other changes you wished you made after the up fit was complete?
