I have a PM3-45 charger, and I'm using it to connect to "shore power" - My question is: Should I connect the charger directly to my auxiliary/accessory onboard battery, or to a positive fuse bus which I use to connect to all other accessories? (Solar panel, separate inverter, etc) or does it not matter? (IE will the shore power from the PowerMAx charger just naturally be pulled to the battery in either case, whether connected to the terminals or to the positive bus).
Also, do I need to do anything with the small "ground terminal" even if I already have a negative/ground connection from the charger to the van's chasis/body ground?
Thank you!
Thank you!
