Don’t sweat it!
So of course the effects of insulation, condensation, heating and cooling all can push the concept of optimizing is various directions.Harry, what fascinates you about those materials?
@HarryNSo of course the effects of insulation, condensation, heating and cooling all can push the concept of optimizing is various directions.
The aspect that I like is that if the slicker / spacer materials are in place between the wall and the insulation, there is an increased chance that the water will have a chance to either drain down or evaporate out of that space vs collect in the insulation.
I have seen in the past how challenging it can be to dry out a vehicle that has had water spilled inside during cold and rainy seasons. I am leaning toward the idea of using a low temperature dehumidifier for colder seasons.
I get your point, but I am really not wanting to go through the effort of installing a rigid insulation. As a result, I need something else to deal with the interface of an inside steel wall and the (not sure yet exactly what) but flexible insulation. Probably won't use thinsulate but will be something flexible, at least in those numerous gaps.@HarryN
Thanks for clearing that up.
In a van that is easily achieved without this drainage mat by simply installing the rigid board insulation with vertical adhesive beads to ensure a 3/8” airgap.
If I get migrating interior air behind my rigid insulation I hope it to be a minor amount, for it to drain if condensates, & not cause mould spores to grow.
I do not see why a DIY van builder would use “Slicker”, but maybe I am missing something? Please let me know if you think I have missed the point.
I get it ... I edited my post above. Consider a total spray job like GaryBIS ?I get your point, but I am really not wanting to go through the effort of installing a rigid insulation. As a result, I need something else to deal with the interface of an inside steel wall and the (not sure yet exactly what) but flexible insulation. Probably won't use thinsulate but will be something flexible, at least in those numerous gaps.
Thanks for the info on the drainage mat - will look into that as well, but many of those types of products off gas when they get hot.
