1 - 4 of 4 Posts
I'm wanting to pre-wire for a Coleman Mach 8 A/C. I don't have the unit but found the manual and other info online. I have a couple questions, the first may be answerable by someone who has installed one.
The first question is where (which side) is the proper location for the wire to come through. The manual shows the the wiring coming through the wooden frame but doesn't really tell which way is front-back-left-right.
The second question is the wire size. The manual, if I'm reading it correctly, says #12 unless the length exceeds 50'. Is #12 the correct size if my wire length is about 15'?
115v 60hz
Amps on high - 15.3
Watts Standard - 1599
Watts Desert - 1913
Discussion Starter · #4 ·
Thanks for the video AZ. That shows it.
I'll have to check that one out Medicineman
1 - 4 of 4 Posts
