Whatever works for you.
Holes!
I got a proper place to build out the van so finally started cooking with home gas (propane in my case?) First up was the fan. I went with the back quarter panel, centered east/west. I was really thinking of using the Hein adaptor, but couldn't decide on where I would put the fan until it was day before, so went with the Butyl tape method. Spent ages quadruple checking my measurements and placements, until finally just getting it over with. Straight forward, fan went in with a tight fit. I made a square frame of 1x2 furring strip on the inside to drill into. I would recommend this route as it gave that back panel a lot of rigidity it didn't have even before a hole.
Next was sliding door window, I went with the CRL FW395R. I chose this setup so maximize airflow from front to back, with the T-vent open and the fan in the back. My plan is to have a countertop run a little way than half the width of the sliding door, with a cooktop right in front of the T-vent. When it's nice out I can have the door open and steam will just go outside, and with it closed maybe some steam will escape through the vent right in front of it. Anyway, here's the XL sized hole.
My 136 had an area on the roof where a 14x14 ish max fan or commercial unit goes and lays flat without any furring needed. The cooktop it right underneath it .It is the most moisture generating item that you have .You can also put small USB fans on the rear flow through ventsHoles!
Did u carve or rout the hanging board or is that store bought?...it looks very helpful to train but do not see any vertical cracks like in the movie...what kind of wood is it made from.....hickory/ash/oakHangboard Install:
So the goal here was to install a Beastmaker 1000 over the sliding door of my Ram Promaster. Location fully inspired by the Honnold Van video we all saw, but the internet was surprisingly sparse with build writeups of how to do it or even finished pics. So I had to reinvent the wheel, and I'm tryna get that karma and help someone out in the future when they're frantically googling on how to mount something flat to something that is anything but square.
The first thing I did was drill 5/16" holes straight through the horizontal rib. The bottom edge is square, but the top is not, so just be careful that your bit doesn't jog back into a location you don't want. To prevent this, I ripped my bottom wood bracket first, then drill holes in the locations I wanted. I clamped this wood piece to the metal rib first, then drilled through the metal. I then used carriage bolts to temporarily bolt it on and move to my next piece. Notice there are washers on the head of the carriage bolts right now. This is just to hold the bottom piece, when you go to install it don’t use the washer and the carriage bolt head will do its job.
Next, I cut a wood piece like below to make my flush mounting surface. Notice it tapers at the top. This is because the metal rib begins to curve on the left side when looking at it. Angles are tricky! This could be avoided by simply moving the hangboard to the right, making it more in the middle of the door. I couldn’t do this as I have a cabinet you would intersect with.
Last was this piece and this was a pain. There are two things going on here. The first is cutouts for those vertical carriage bolts I put on earlier (which are routed out to make room for the nuts), the second are holes for bolts going front to back of this piece. It was tricky to get the angle right for these bolts, but some 9th-grade geometry will get you there. You can see the holes where those bolts thread through in the below picture. Without these bolts, the force from the hangboard would just rip this top piece off. Then I countersank those bolts so now there’s a flush, 90 degree, mounting surface for the hangboard!
Woohoo, looking good!
The next step was gluing the ever-living **** out of it. I used Gorilla Glue Construction Adhesive.
Also, I drove in some screws from the top down into the metal rib for that top wood piece. And straight in the middle wood piece. This was definitely overkill, but it was a reason to buy a swanky 90-degree impact attachment, and why pass the opportunity for new tools up?!
Finally, glue and screw the hangboard to the wood mount you just made. This part is messy, so put something on the ground for all the wood glue that will drip.
We did it! Good job team. Time for a beer and once again blow off hangboarding.
My assumption wat that the hangboard itself is a store bought product, mounted to the ridiculously strong backing.Did u carve or rout the hanging board or is that store bought?...it looks very helpful to train but do not see any vertical cracks like in the movie...what kind of wood is it made from.....hickory/ash/oak
no sapwood....looks all heartwood with no pith
Thanks! I really haven't been using it too much last few months, an occasional weekend trip. But the bed is still bomber, so issues at all with it.Nice work on the van so far! Have you been getting out in it during the last few months? How is the bed holding up?
On another note it seems like there are quite a few climbers building vans on here. Someday we should have a climbing meet up 👍🏻. The wife and I spend most of our summer weekends in the Voo if anyone wants to hang and get slapped on some wide.
The hangboard is store bought, though it's certainly a design one could replicate. I actually don't know what type of wood it is but it's from the U.K. so maybe timber? (bad joke) Hangboards are used in climbing to specifically strengthen finger tendons, so its purpose is a bit different than a crack machine to train "jamming" for vertical cracks in the movies.Did u carve or rout the hanging board or is that store bought?...it looks very helpful to train but do not see any vertical cracks like in the movie...what kind of wood is it made from.....hickory/ash/oak
Well, I started 2020 by quitting my job to build the van and climb for a year. Needless to say, things didn't go as planned, so I went back to work and things have progressed muuuuch slower. That being said I neglected to continue with updates to my build thread though I have been making other progress. The hangboard I actually finished in October. I'm almost done with the electrical and I'll make that post imminently.My assumption wat that the hangboard itself is a store bought product, mounted to the ridiculously strong backing.
@juddnelson why the long break?
We built one on the ceiling in the garage! I like to call it the gobie machine...While it would be awesome, a crack trainer would be a tough fit in the van....see below
DIY Crack Machines
yeah...i was thinking using vertical cracks to climb upwards.....did not think of climbing parallel hanging underneath.....saw video of underneath loft bed.....technique was inspired for a non climber to view.....good luck and strong rockThe hangboard is store bought, though it's certainly a design one could replicate. I actually don't know what type of wood it is but it's from the U.K. so maybe timber? (bad joke) Hangboards are used in climbing to specifically strengthen finger tendons, so its purpose is a bit different than a crack machine to train "jamming" for vertical cracks in the movies.
DIY Crack Machines
Killer! On track for Century Crack?? 😂We built one on the ceiling in the garage! I like to call it the gobie machine...
Excited to see the electrical
