21 - 32 of 32 Posts
'17 136 HT Black
I've been looking for an alternative housing on my black van, this might be my answer with the slight modification.
Sorry just saw this. They have been dry as toast and really like the look.
I can second this comment. I have zero leaks/water issues, and I really like the look they give. (y)
'17 136 HT Black
Just to piggyback on this thread, I ordered mine on Ebay for around $30. They say they will fit a Promaster w/out any modifications other than wiring. Should be getting them delivered soon.
2019 Ram Promaster 136 HT Gasser Stealth Work Van Weekend Camper
Looking to do the same , Keep us updated Thanks.
'17 136 HT Black
I got the lights in and I mocked one up. The screw holes don't line up, almost an inch of difference. They will each need a little bit of wiring and 1 screw hole drilled into the roof if you were to buy those lights. It's not a lot of work, but I'm just not sure if the juice is worth the squeeze.
2018 136 HR Ont.
So the mod was to drill a new hole in the new light base 1/2" further back.
Can you modify the light to fit without drilling a hole in the roof?
Had a feeling wouldn't work as direct replacement , thanks for the update. ( I bought 2 different sets online in the past , application guide said would fit , they did not ( I'm still interested if anyone finds replacements in smoke )
2018 Silver 159 HT
Discussion Starter #31 (Edited)
The ones I got were plastic and was able to drill a thru hole in them to use the OEM mounting holes. Very easy mod. I did have to cut off the factory inline connector. It seems some of the LED lights are now coming with a small white connector that will fit the existing mating base connector.
21 - 32 of 32 Posts
