I been think a lot of about cheap way to track our van in case it get stolen. My van already have a gps tracker via my mobile router and wifi camera and door sensors. But in case it was disable, I want a redundancy cheap tracker that doesn't have monthly fee and relatively cheap. I think the two big player are Apple Airtag($30), and Tile($35). Both of this tacker doesn't have any gps but relying on crowdsourcing gps data from other user's phone. There is actual gps tracker like Spot but they are pricey and require a month fee.
I been testing Tile for a few days and found it not very useful since there isn't many tile users in my area and require the user to download the app. Once I leave the house, the tile tracker at home will get disconnected even though it tells me there is over a thousand user within my area. Tile does have higher tracking range(250ft-400ft) than airtag(33ft) but in real life probably less than half of those values. Also you can share your tracker with others so they can track your location.
Airtag might be better since it ping off nearby iphone without needing to install additional app and there are a lot of iphone user out there. But only iphone user can use this tracker so if you using andriod user Tile is the only option. Airtag only allow one single user for each tracker so you can't share your location with others.
My plan is to put both trackers in the van so I get more crowdsourcing coverage.
Also its probably best to place the tracker closer to window or outside of the van for best tracking range and this only work in area there is cell reception.
