Has anyone changed their front seats? Did you confront the airbag? Anyone local in Ca. Or. that can do this? These seats are uncomfortable. Please help!
Nice work and design all around! Especially the rack! Thanks for sharing with us.Here are a few pictures of the work in progress. Here are a few details. The rims came from EuroCampers. The tires are BFG KO2 245/75/16 very slight rubbing in front under extreme compression, this is after I cut away about 3/4 of an inch around the the inside of the fender, snow chains may be a challenge. The windows are from Motion windows, good quality but 7 week lead time. I did a vinyl wrap around the windows. I built the rack and ladder out of 16 gage steel and had it power coated. On the roof are 2 Grape solar 160 watt solar panels along with a Midi Heki skylight. The sofa is a Flexsteel Magic bed. The cabinets are a combination of steel and wood. The upper cabinet doors are a pre curved wood and the steel frames are bent to match the curve. The kitchen cabinet has a trash can incorporated in it and a fold up table. I'm going for the Restoration Hardware distressed look. The refridgerator is a 2 way ( 12v 120vac) Nova Kool that I have running 24/7. Between the batteries and the solar the refrigerator uses very little power. With any luck I will have it done in a few months. Many thanks to the other forum members, I got a lot of good ideas from them. I will continue to post more pictures as I progress.
