1 - 3 of 3 Posts
What is the easiest way to wire up cargo lights?
I tried tieing into exist lights, when they time out the led's flicker
Idealy would like to keep original cargo lights and have additional leds switched. But it seems 12v tie in point in the rear is non existent. I do not really want to go through A pillar due to air bags. Any ideas?
No wiring at the bottom of pillar at passenger seat, or none that I could find.
It may be best to get a wire feed from the battery directly, fused and fed along the drivers side floor where there is a wire channel built in, and then into the B pillar on that side. From there the feed can cross the van inside any roof rib. Led bars and even remote controllers are easily sourced from the internet. The feed can be just a positive wire and let the chassis cary the ground.
Take out the plastic cover on the step on the driver’s side to see the path. Easy Peasy.
1 - 3 of 3 Posts
