I spent the day trying to do a simple spark plug change on my 2014 Promaster 2500 159 gas van.
After 5 hours of trying to get the top cover of the engine off, I gave up.
I'm getting rid of this van and going back to a Sprinter. This is the last straw after two engines, 186k miles, several repairs, continuous bulb failures, and a radiator that still leaks after being replaced.
This top cover's only purpose is to route air from the throttle plate into the cylinders, and there is no reason I can see as to why they designed it to cover the entire top of the engine.
Let me warn you that there are 12 bolts and screws holding this on, not including the hoses and wires that have to be unplugged and moved. There are double brackets in front by the radiator and in back down by the engine block where you can't see. One of the bolts on the front is blocked by a metal hose and brace. The rear bracket will not come off even after no screws and attempts to pry it off.
This layout is a classic example of engineering and design taking priority over maintenance and repair. And the van is downright ugly in the front.
The engine compartment is too small. This top cover was designed too big for the space, and I couldn't get it off. Maybe someone has.
I have had to work on a lot of my vehicles over the years, and I've seen stupid designs that make repairs harder. A simple spark plug change should never be this hard.
