I have a WIFCO converter which gets its power from a 110 volt power cord, gets 12 volts from my battery set and has breakers for the three 110V outlets in the van, and which then can supply the 12 volts and charge my batteries when it os plugged in, it has fuses for my 12 volt stuff and gets voltage from my battery set or converts it to 12 volts if plugged in for that. Normally the 110 volt outlets are not on of course as it is not a 12-110V inverter.
I also have a 1500 watt inverter that has a pair of 110v outlets and it is fed right off the battery set.
Is there a way to feed the inverter's 110 volts into my outlets from the converter and get the convenience of having 110 volts when I turn on the inverter? I'm thinking no as it would feed the WIFCO back through the outlets. At home I have a UL approved mechanical lockout for my load center for when the generator takes over in power loss situations. It prevents the linemen from seeing my 110/220 volts fed back over the downed lines and allowes only one source- generator OR line power.
Is there a way or do I run additional circuits and label them "inverter" and the present ones "converter"? Since I have only a few and plug only one thing in at a time I have considered split wiring the recepticles and having the top be "inverter" and the bottom being "converter"
If none of this makes sense to you welcome to my World!
